User not getting invite email
We have checked to make sure of the following:
  1. We are on the same network, another user also on the same network received his invite. We all have the same security settings.
  2. I did send it to her Autodesk ID associated email address.
  3. Checked spam folder system.
Only one user is suffering the issue.
Tried using the team url to go directly.  That said wait for the invite.
Is there a way for an invited user to by-pass getting the welcome email.
David Haynes
It appears that if they don't have Autodesk Account Management entitlement, the invite goes into some 'black space' in Autodesk; meaning, no notice to anyone, but no invite processing either.
David
So... What did you do to get the invite to the user. I have the same issue.
It is important that the Contract Holder (or Software Coordinator) for your company do the following:
1. Go to manage.autodesk.com
2. Verify that the BIM 360 entitlement shows up in the "All Products & Services" Tab (on left side of screen)
3. Verify that the user shows up in the "Users" Tab (on left side of screen).
4. Users Tab > Select User > Select "Edit Access".  Make sure the user has BIM 360 Team access.  Note:  Collaboration for Revit entitlement includes entitlement for BIM 360 Team.
Now in the BIM 360 Enterprise Hub (this must be done by BIM 360 Team Site Administrator:
1. Select BIM 360 Account Administration
2. Account Admin>Member Directory - see if user has been invited.  You can also resend invitation from the "More Actions" box.
Hope this helps.
David
gsucci
superseded...
gsucci
How do you invite someone without him being in your Users list?
I have my hub, but invitees have their own C4R subscription... They should not need to be in my "Users" list, correct?
thank you
PS this whole BIM360 is soo cumbersome for the simplest operations: project members? Editors? Project collaborators? Entitlements? Licenses? Seats? Hub administrator? ... Can you guys find any more confusing terms?
So after going back and forth with Autodesk support we finally came to the conclusion that the only way to get that particular user and invite was to send them a direct link the URL of the project from then 360 team and then they were able to get right in see the invitation accept it and then become part of the team
