Good Morning Everyone, my question is if can i download or edit files holder in BIM 360, on revit software.
Solved by patrick.beattie. Go to Solution.
Hi @Anonymous,
Thank you for posting to the BIM 360 Design Collaborartion forum. Are you asking whether you can edit Revit models that are hosted in BIM 360?
You can absolutely edit Revit models using BIM 360 Design and the Design Collaboration module. You can find out more information reading through the forum post Getting Started With BIM 360 Design. For general information please visit https://info.bim360.autodesk.com/bim-360-design.
If you consider your post resolved, please choose Accept as Solution so that others can find the answer as well.
Best regards,
Patrick B.
Global Product Support
Hi @Anonymous,
Best regards,
Patrick B.
Hi @Anonymous,
I just wanted to follow up with regards to my response to your post. Did the information I provided help answer your question?
If so, please choose Accept as Solution so that others can find the answer as well. If you have any additional questions or comments please let us know.
Best regards,
Patrick B.
Hi @Anonymous,
Best regards,
Patrick B.
