BIM 360 Support
Welcome to Autodesk’s BIM 360 Share your knowledge, ask questions, and explore popular BIM 360
BIM360 Docs - Visibility LineThickness On/Off
3 REPLIES 3
r.drolc
295 Views, 3 Replies
Hi ALL,
Apologies if this query has been questioned before (I couldn't find anything in the forum), but is there a way of switching off linetypes in BIM360 docs?
I need to stress, this is not through Revit, I know in Revit you can use TL (thin lines) to control on/off line thickness, so I'm wondering if there's a similar setting in BIM360 docs. For context, I'm viewing a structural engineers drawing/model and can't amend it. I simply want to switch off the line thickness.
Any help, would be greatly appreciated.
Many thanks
R.
3 REPLIES 3
r.drolc
in reply to: r.drolc
@bhantaredii Apologies, I'm unsure if you've posted your response on the correct query. Not sure how your response correlates to my question. Sorry if I've missed your point.
lokesoken
You're right, it shouldn't be a problem but it is. BIM 360 unfortunately can't handle "large" projects that can easily run on desktop. Worked on a massive project and when we asked autodesk why it's acting up, they basically told us it's because of B360's limitations. https://omegle.onl/   https://xender.vip/
kinopbonil
What sets me off most about BIM360 is that a lot of this functionality should just be native and not behind a $900/yr subscription per user
The fact I can't even share files across this platform with those who dare not have a subscription themselves is probably the most pathetic thing about it.
