Hi ALL,
Apologies if this query has been questioned before (I couldn't find anything in the forum), but is there a way of switching off linetypes in BIM360 docs?
I need to stress, this is not through Revit, I know in Revit you can use TL (thin lines) to control on/off line thickness, so I'm wondering if there's a similar setting in BIM360 docs. For context, I'm viewing a structural engineers drawing/model and can't amend it. I simply want to switch off the line thickness.
Any help, would be greatly appreciated.
Many thanks
R.
You're right, it shouldn't be a problem but it is. BIM 360 unfortunately can't handle "large" projects that can easily run on desktop. Worked on a massive project and when we asked autodesk why it's acting up, they basically told us it's because of B360's limitations. https://omegle.onl/ https://xender.vip/
What sets me off most about BIM360 is that a lot of this functionality should just be native and not behind a $900/yr subscription per user
The fact I can't even share files across this platform with those who dare not have a subscription themselves is probably the most pathetic thing about it.
