This subject has been raised, but I wanted to describe exactly what the problem is. When user publishes NWD file containing point cloud in Navisworks with "Embed ReCap and Texuture Data" option checked:
![Publishing.png Publishing.png](/t5/image/serverpage/image-id/714037iA46667D4F741683E/image-size/medium?v=v2&px=400)
And when load it with BIM 360 Glue, a message appears: "Gluing error".
![Gluing error.png Gluing error.png](/t5/image/serverpage/image-id/714038iD1BE91F09422D4AE/image-size/medium?v=v2&px=400)
Only saving the file as NWD with appended *.rcs scans and saved locally allows to open the model from BIM 360 Glue. This is a big limitation especially if there are many people working on the project in different locations. Then all users must have the same path to the file e.g. C:\cloud.rcs.
![Path.png Path.png](/t5/image/serverpage/image-id/714041i0B5FE7105EB26D5B/image-size/medium?v=v2&px=400)
Adding models to the BIM 360 Docs and pointing the path to *.rcs files using Autodesk Desktop Connector also does not solve the problem because the drive is user-specific: C:\Users\<user name>\BIM 360\<hub name>\Sample Project\Project Files\<file name>.rcs
It would be great if the point cloud was more supported by BIM 360.
