In case the length of the path to a file including filename exceeds 260 characters, the upload process does not work properly.
Example: C:\Users\GRZPAT88\BIM 360\Andritz AG\Bracell Pilot\Project Files\Recovery Boiler\Engineering and Design\Equipment Engineering\EXEMPLARY FILENAME
For some projects, the file name can be a concatenation of multiple criteria (e.g. internal document number, discipline, sub-discipline, sub-supplier document number, etc.) - so in those cases the maximum length limitation is exceeded.
When uploading the file to BIM360 via Autodesk Desktop Connector or via drag & drop command in Document Management folder structure, the process fails.
Additionally, in case there are hundreds of files uploaded at once, no detailed error log is shown that indicates which of the files have been uploaded successfully and which failed.
As a result, currently no file is transferred even if some are not affected by the file name length limitation.
In Desktop Connector under the setting "Desktop Analytics" there is a way how to find out which files are affected but that's manual investigation and unmanageable in case the amount of files increases.
We would await the Desktop Connector to distinguish and indicate to the user which files need “post-processing” easily not by investigating and managing it manually.
