Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Desktop Connector support for Mac or Windows ARM
Would be great go get this supported natively on Mac OS or failing that get it working again under Windows ARM. Revit now runs pretty well under parallels on M1 Mac's but desktop connector no longer installs - fails on the filter easyflt.sys (something like that). Earlier versions used to install I'm sure but not the last few latest builds.
83 Comments
peyton.park4D2L6
Observer
Same problem, the Autodesk file system monitor system monitor service will not run and the install will not finish on Macbook Pro M3with Parallels 19.4. Please fix Autodesk.
cchollet
We are still wating for M2, hopefully they hear you M3.
AUTODESK WHEN ARE YOU GOING TO LISTEN TO US AND FIX THIS ???
USBIM_MJMoore
I am running Revit 2022, 23, 34, 2025 and several other Autodesk software on my M2 MacBook Pro via Parallels. It works perfectly, especially with the new Vision Pro's. However, we still do not have a working Autodesk Desktop Connect for Windows 11 ARM.
I have a desktop PC with an H drive where I place my desktop connect projects. This drive is shared and mapped to MacBook. It is accessible to my MacBook offline so I can still use it and save files to it when I am out of town. When I arrive back to my office, I allow time for my MacBook to sync these files back to my desktop.
These files will not be real time updated when I am away.
cchollet
Hi USBIM...
The main Issue still exist..."However, we still do not have a working Autodesk Desktop Connect for Windows 11 ARM. "
WE NEED AUTODESK TO FIX THIS FOR US !!!
THANKS.
cchollet
AUTODESK, ANY NEWS ON DESKTOP CONNECTOR FOR WINDOWS ARM ???
gfwilliams
So, I noticed with the last desktop connector update that Autodesk provided guidance on installing the Desktop Connector within a virtualized environment. I don't know if anyone here is attempting to run Revit on a windows-on-arm machine natively, but my issues are all within Parallels on a Mac. So, while these issues may seem to be related to non-persistent VMs, the solutions in the help document may provide a solution for us as well.
https://help.autodesk.com/view/CONNECT/ENU/?guid=Virtualization
Anybody have time to review and/or test this?
NedyalkoDemirev
Autodesk Inventor is crucial for our company, and we are unable to use it without Autodesk Desktop Connector. We tested it on our MacBook Air ARM-based laptops with Windows 11 ARM installed via Parallels. Unfortunately, Autodesk Desktop Connector does not install. We identified the driver causing the issue and opened an issue on their GitHub page. It would be great if you could support it.
EaseFilter FilterDriver GitHub
StefanRademan
Community Visitor
Very Frustrating. Up to Revit 2024 seems to work well on Parallels. Unfortunately Desktop connector doesn't, so the entire project environment inside Autodesk Docs and Collaborate which Autodesk is so aggressively promoting falls flat.
JD_AGPL
Also supporting this cause.. I am working on an M3 MacBook and running Inventor and Vault fine via Parallels. the issue is installing Desktop Connector to integrate properly with Vault - need this running. Thanks.
etai6TG52
I seem to have found a solution - basically pre-approve projects on a pc and then keep working on the mac:
1. open desktop connector on a pc
2. login with your user
3. select all the projects the user will be working on
and - voila
open revit in mac/parallels - and it all works again.
cchollet
etai...
We can open the files and work on them with no Issue..
The Issue with not Installing ADC is that you cannot reload Links, Browse the Project Files on Windows Explorer to modify them, like Keynotes, Links (Dwg, Revit, etc)
Or maybe I am not understanding your Fix...
Thanks.
AUTODESK, PLEASE HEKP US WITH THIS ISSUE, UPDATE AUTODESK CONNECTOR TO BE ABLE TO INSTALL ON WINDOWS ARM !!!
ciccicla
Autodesk we need Desktop connector working on windows ARM!
ErikFrandsen
we need autodesk desktop connector to work on parallels using a MacBook with a M chip. Please help us Autodesk...you are our only hope...
jean-marc_percebois
Hello, we need a connector on Windows ARM for chips M1...M4
please.
gchapmanLD2SS
Community Visitor
Pretty please make this work!
A.J.Corbitt6736
Nothing better than waiting for years for software.
Hours seem like days..... years seem like decades.
jason_isherwood
I wonder will we hit the 4 year mark without any response from Autodesk.
Wish I could to a poll  !
I could probably predict
No response from Autodesk within 4 years of waiting.                 100%
Autodesk respond , we are thinking about thinking about it.           0%
wwessels-2041
I would really like this to get fixed. I just tried to get this installed and it didn't work. Same issue FilesSystem Monitor
c_parri_ext
It’s truly an absurd situation that a software house of this caliber is incapable of creating an installer for ARM processors.
cchollet
AUTODESK,
WHEN ARE YOU GOING TO HEAR US ???
ARE WE NOT THAT IMPORTANT TO YOUR COMPANY ???
I’VE BEEN A USER SINCE 2005…
FIX DESKTOP CONNECTOR FOR WINDOWS ARM, VEVERY DAY THERE ARE MORE MAC USERS IN YOUR FIELD !!!
