Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Resample Strandes can t find
9 REPLIES 9
Message 1 of 10
g_hydrio
455 Views, 9 Replies
I have a problem in bifrost, i want to follow some youtube tutorial but when i will load a resampleStrandes i can t find it in the list. Have i to download it ?
Thanks ๐Ÿ™‚
Tags (1)
Labels (1)
9 REPLIES 9
Message 2 of 10
resample_strand is a native node since Bifrost 2.7.0
https://help.autodesk.com/view/BIFROST/ENU/?guid=Bifrost_Common_reference_geometries_resample_strand...
for older versions you need maximes compounds.
https://mjcg.gumroad.com/l/mjcg_compounds
https://linktr.ee/cg_oglu
Message 3 of 10
Ok thanks for your answer. But what compounds from maximes replace the resamplestrandes? I allready have his compounds pack 2.1.1 .
Message 4 of 10
It does have the same name. Are you sure you have installed it correctly?
Message 5 of 10
g_hydrio
in reply to: g_hydrio
hum
Message 6 of 10
Hum i think .
I have copy the compouds from mjcg in the folder autodesk C:\Users\autodesk\bifrost\compounds
i see the copied compounds in graph editor.
i have copy the graphs folder in program files, i can use his graphs in maya.
i also can t find a file with this name in the folder of mjcg that i download
Is my process correct? Maybe i need to dowload a older packs than the 2.1.2
Message 7 of 10
g_hydrio
I Don't understande ๐Ÿ˜ž i have search for hours and impossible to find that file.. i have try differents pack version of mjcg. that's crazy ๐Ÿ˜ž
Message 8 of 10
sepu6
Christopher gave you the wrong info. Resample strands have never been part of the MCG compounds.
It was part of the Rebel Package now part of BF since 2.7 I believe. Depending on the version of BF that you are using you need to install the correct version of the rebel package.
Which you can find here
https://area.autodesk.com/m/jonah-friedman/assets
Message 9 of 10
g_hydrio
Thanks man ! So i'm not crazy! ok I will search the good pack.
Thanks!! your the best ๐Ÿ™‚
Message 10 of 10
Sorry for the confusion.
I mixed it up with resize_strands.
