resample_strand is a native node since Bifrost 2.7.0
for older versions you need maximes compounds.
https://mjcg.gumroad.com/l/mjcg_compounds
Ok thanks for your answer. But what compounds from maximes replace the resamplestrandes? I allready have his compounds pack 2.1.1 .
It does have the same name. Are you sure you have installed it correctly?
I Don't understande 😞 i have search for hours and impossible to find that file.. i have try differents pack version of mjcg. that's crazy 😞
Christopher gave you the wrong info. Resample strands have never been part of the MCG compounds.
It was part of the Rebel Package now part of BF since 2.7 I believe. Depending on the version of BF that you are using you need to install the correct version of the rebel package.
Which you can find here
https://area.autodesk.com/m/jonah-friedman/assets
Sorry for the confusion.
I mixed it up with resize_strands.
