Hi ,
I have issue switching to proxy . When im in Var01 , nothing is shown when i turn on proxy . But, when i'm in Var02 , proxy.usd is loaded when i turn on proxy . I followed exactly as the video (https://www.youtube.com/watch?v=kPlQasuHkNU). And still have no idea how it happened . File attached for checking . Thanks
# Error: Failed verification: ' handle.isValid() ' -- Cannot get path from invalid object handle
System : Windows 10 x64 , Nvidia Quadro RTX 3000
USD plug in : 0.16.0
Arnold plug in : MTOA 5.1.0
Maya 2023
Hi there, I also got the same problem. I created a variantset with 2 objects. The one is showing when I switch them up and the other one does not show at all. Somehow the mesh won't import correctly. (when I import it via maya import, the whole mesh is showing correctly) Did you solve the problem?
What version of BF and Maya USD are you using?
Is working correctly here, using 2.7.1 and USD 0.23
