How to get the correct output array from a do_while inside of a for_each?
mcw0
Advisor Advisor
mcw0
I have an array of point positions that I want to pass through a do_while loop until a certain condition is met.  My input arrays are all set to "Set Port Iteration Target" = True.  The problem I'm having is the data coming out of the do_while is all the same.  Every index of the output array is the same value.  I would have thought setting the port iteration target would have informed the do_while to populate the output indices accordingly.  But it doesn't.  So what's the trick?  How do I get the correct output in this situation?
mcw0
UGH!!!  ID.10.T strikes again!!!  My bad.
But it doesn't explain why every index in the array was the same value.  But at least I got the values I wanted...so moving on.
