Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
Geometry motion blur
6 REPLIES 6
Aslan.Jafari
779 Views, 6 Replies
A simple compound to simulate the effect of motion blur, by blending between the current and last point positions of the geometry.
It uses point normal and point velocity of the geometry to create a weight map.
weight_by_rotation_angle.json
weight_by_rotation_angle.pngThis map is then used to blend between the current positions and last known position of the object via a lerp node.
Dependencies:  force_pull_port and compute_point_velocity from rebelpack.
Aslan Jafari
Sr QA Analyst
Labels (1)
6 REPLIES 6
mjcg91
in reply to: Aslan.Jafari
awesome 🙂
Maxime Jeanmougin - Technical Artist
https://maximejeanmougin.com
Join the Bifrost Addicts community on Discord:
https://discord.gg/bifrost-addicts
Nicely done Aslan! Will be super useful in animation as a lag deformer 👍
sklauss
very cool, will try on a char anim of mine.
Hi Aslan,
Do you mind uploading a scene with the compound attached to a example mesh? I am fairly new to Bifrost and I can't get my head around it very well. I would love to try this compound, it looks amazing.
Here is a simple example that uses the compound.
Animated sphere moving around and deforms based on it's animation.
I am using the point_weight to blend between two colors in the Hypershade as well.
Note: I made the geometry_motion_blur  compound local to this file. you may replace it with your referenced copy if you like.
Hope this helps.
Aslan Jafari
Sr QA Analyst
Absolute legend! Thank you so much. Will give it a go now!
Technology Administrators
