flatten_nested_array
GonzoD
GonzoD
I am using Maya 2020.4 trying to follow along with the Bifrost graph video: https://www.youtube.com/watch?v=rUY9pO7UCjs&ab_channel=MayaLearningChannel
Which is on the Maya learning channel.
The flatten_nested_array node doesn't come up when pressing tab. I have checked under the all selection as well, but I can't see anything. In the comments for the video, someone else had this issue 2 years ago. He was using version 2.0.0.0, I am using 2.1.0.0. Is there a fix for this?
Any help would be very much appreciated.
I am running a Windows 10 machine, 32 gig ram, i7 2.60 GHz intel processor, Nvidia GeForce GTX 980M (yeah it's an old machine).
sepu6
2.1.0.0??? wow, that is old. You know you can run the latest version of Biforst 2.6 with Maya 2020.4 right? And if so you will find the "flatten_nested_array" node and you will have a much much better experience.
Now I can't remember if that came with the core nodes in 2.1.0.0 maybe you need to download the rebel package for that version.  So try that from here
https://area.autodesk.com/m/jonah-friedman/assets/rebel-pack-030
But I would highly recommend upgrading.
GonzoD
Thanks for the info, I didn't know you could run later versions of bifrost on 2020 but that helps a lot.
