Bifrost scattering
hintzjt7
Bifrost scattering
hintzjt7
How can I get scatter points to arrange in a certain order like the way the scales on this Gila monster are grown. I colored several blue to show that. Also, how can I get scales to become flat on the surface of a model after scattering them?
Replies (9)
Christoph_Schaedl
Even if you find a way to place the scales in the main body area in that pattern you have a problem in the more complex areas around the limbs or eyes. I would use the topo as a guide. So you have full control over the placement and it would work even if the gila is moving.
https://linktr.ee/cg_oglu
hintzjt7
What about laying over the surface?
Christoph_Schaedl
Yes i would layer them on top of the geo. But use the center of the faces to place the scales.
hintzjt7
Earlier you said to use the topology as a guide.
Christoph_Schaedl
Yes the topo is the guide to place the scales. You have ot model the body in diagonales to get the pattern.
hintzjt7
If I want the desired scattering I showed you with the blue colored scales, would I have to use the triangulate mesh node?
Christoph_Schaedl
No model the basemesh by hand.
hintzjt7
Never mind what I said about the triangulate mesh node. Would I have to select the vertices for the desired pattern?
Christoph_Schaedl
Based on all your question here in the forum you arnt a Senior TD. Without the needed skill you wont be able todo that in Bifrost. You need to develop your own tool/graph in bifrost.
