Bifrost Forum
Welcome to the Bifrost Forum. This is the place for artists using Bifrost to ask and answer questions, browse popular topics, and share knowledge about creating effects procedurally using Bifrost. You can also visit the Bifrost Community on AREA to download an array of ready-to-use graphs, read Bifrost news and updates, and find the latest tutorials.
bake_instanced_geometry_v2_7_1_0 vs newer versions
3 REPLIES 3
brandaosa
116 Views, 3 Replies
Revisiting a project I made one year ago (2023), I found out (after spending some time!!!!! - thanks) the bake_instanced_geometry node on newer (current) version is not passing all properties forward?
Create Instances on the graph below is receiving a animation from 10 frames static mesh created in a snapshot.
Using the current node version the baked instance will pass no UV information? the texture gets broken, displaying a single color, no matter what texture I use. While this is not happening if I switch to the same node on  2_7_1_0 version.
Labels (4)
3 REPLIES 3
Looks like a bug. Its also mentioned here with a manual workaround.
https://discord.com/channels/872260298508222534/1241118631673204898
https://linktr.ee/cg_oglu
sepu6
in reply to: brandaosa
is a bug as Christoph said.
We've logged BIFROST-10368 to resolve this issue. Thanks!
Technology Administrators
