Hi guys,
Does anyone know if it's possible to vary color emission on an aero source by point? I've looked at the graph example of emitting multiple colors, but that only emits a single color for the entire emitter. Is it possible to vary the color emission of a single emitter? I've tried setting a point property and named it the same name as the additional property, but the aero solver doesn't pick up the per point settings. The documentation doesn't appear to give much of a hint on how to accomplish this task.
Solved by stamatk. Go to Solution.
Hi @calibrix
It's possible to do what you ask using the vary_source_property node but unfortunately it's a bit convoluted due to the internal naming conventions for custom properties.
Essentially, if you create a custom float3 property to drive color and name it "foo" and you want to randomize it per point, you have to enter the name "point_foo__" in the vary source property, and then call it using "voxel_foo" at render time.
This is ridiculous I know and we're working very hard to streamline all this. Your patience is appreciated!
In the attached images I create a float3 property to drive color per point using the vary_source_property
Hi @moiamy
Yes it is still the same in 2.3, but only for a little while longer. While we now support plugging fields directly into most simulation properties, we are still working on the custom properties, like the one you would create for color.
Thank you for your patience!
Kosta
