Would it be possible to post a screenshot/gif for the above node and how it
should be hooked up? From, what I read it is quite simple, just plug it into
the additional settings and supply a path to a bob cache. I tried with Aero
and Particles and it still solves as before.
Solved by stamatk. Go to Solution.
Hello @sklauss
Here is a link to a couple of videos which explain the fundamentals of initial states and the semantics for aero. Hope this helps.
Cheers,
Kosta
