Hello!. I want to use a model I found but the format is in .cad, I did a lot of research and can't find at least a demo or trial of QuickCAD that I think was used to create the file. I downloaded other CAD programs but none recognize .cad
Can someone assist me to convert the file?, I really need access to the file, and converting to .dwg will give me more choices to use the file (at least open with DWG Trueview?).
Solved by Kevin.Hutch. Go to Solution.
I have had some success with CAD files and am willing to try for you, post or send a file and I will have a look at it, Autosketch can;
READ
AutoCAD Drawing File (*.DWG)
Autosketch (*.SKF)
Autosketch v2.x (*.SKD)
Drafix CAD v3.x/v4.x (*CAD)
Drafix CAD PORt
Drawing Interchange (*.DXF
QuickCAD (*.CAD)
Windows Metafile (*.WMF)
WRITE
AutoCAD 2000 DXF (*.DXF)
AutoCAD 2000 Drawing (*.DWG)
AutoCAD 2004 DXF (*.DXF)
AutoCAD 2004 Drawing (*.DWG)
AutoCAD 2007 DXF (*.DXF)
AutoCAD 2007 Drawing (*.DWG)
AutoCAD R12/LT2 DXF (*.DXF)
AutoSketch (*.SKF)
AutoSketch v7/v8 (*.SKF)
Autodesk Design Web Format (*.DWF
Bitmap (*.BMP, *DIB)
GIF (*.GIF)
JPEG (*.JPG, *JPEG)
PNG (*.PNG)
QuickCAD (*.CAD)
TIFF (*.TIF, .TIFF)
Windows Metafile (*WMF)
One done others as per the PM just pick the format from the list.
Best of luck with your parachute.
Really thank you, you saved me a lot of trouble converting this file!. Thanks for the good wishes!.
I could not find the extra files, so I assume these are the ones and I have converted them to ACAD 2007 DWG format.
If the package you are reading the files does not allow you to "tile print" to actual 1:1 scale attached are the PDF tiled version of the 150 parachute panel on 6 x A4 pages. I added the crosshatch to make it easier to align the pieces into one sheet and added the dimensions to confirm the size.
Hello!
I'm hoping you could help me convert my .CAD file. I've been searching all over the web without success.
I ran it by in filext.com and returned the following results:
DOUBLE SHORT
March 6, 1992 Drafix Windows CAD IBM PC !1989-92 Foresight Resources Corp.
Hatch32580k
C:\CAD\slb\tutorial.slb× 433333
SymbolType
SymbolDesc
SymbolName
Hope to hear back from you.
Best Regards,
I have had success loading with some .cad files into Autosketch send me a file and I will try for you.
Attach it here or send it direct to my kevin.hutch@hotmail.com account.
Sorry I can not open the RAR file.
Success in converting as attached.
Hello Kevin @Anonymous
I also need to convert .cad files to .dwg please !
Can you help me too?
I have had success with some but not all CAD files as this extension has been used for various software, send me the file and I am only to willing to see.
Hi Kevin
I need to convert some .cad files and hope you can help me, I need them either in .dwg or .pdf
As mentioned earlier in the thread there are many file types that Autosketch can read but .CAD has been used by several other packages. I have had success with some but not all CAD files as this extension has been used for various software, send me the file and I am only to willing to see.
