Update Install Failed
Message 1 of 16
When I try to install Update from Application desktop, I  receive this error:
"Unable to verify digital sign for this installation"
and the installation failed.
I have to setup any otion?
Replies (15)
Message 2 of 16
pendean
Community Legend
Community Legend
Get your updates through the UPDATE link on your accounts webpagehttps://manage.autodesk.com/cep/#products-services/all , choose the webbrowser-download method, then install your updates: does that solve the problem?
Message 3 of 16
Thanks for your suggest, I still use this solution, but I can not understand why I can not download from the application...
Message 4 of 16
pendean
Community Legend
Community Legend
Message 5 of 16
HI,
I have tried it but not working
Message 6 of 16
srinivasarao.potla
Hello@scarta
Thanks for your feedback.
Could you please check that, client machine have Autodesk root certificates or not?
What is the version of autodesk desktop app you are uing?
Please try this
  • Exit ADA(from system tray menu)
  • Stop AdAppMgr Service (windows task manager)
  • %Programdata% > Autodesk > Delete the “SDS” folder
  • Restart ADA.
Still you have problem, please try this,
I would like to know more about the issue. could you please send me the log files?
Please find the attachment for log file instructions.
Srinivas.
Message 7 of 16
HI,
the version is 7.0.6.378
In attachment you can find log file
How can I check if i have Autodesk root certificates ?
Message 8 of 16
srinivasarao.potla
HI scarta,
Thanks for your response.
May i know the update which you were tried to install and got the error?
Here is the steps to check Autodesk root certificates.
1.search for “certmgr.msc" from windows search
  1. click trusted root certification authorities
  2. click certificates
  3. check for Autodesk-CA and Versign certificates.
Please find the attachment for screenshots.
Srinivas.
Message 9 of 16
HI,
I checked for certificates, I have 3 Verisign certificates but I don't have Autododesk.
Stefano
Message 10 of 16
srinivasarao.potla
Hi Scarta,
Thanks for your update.
Could you please mention the name of the update you are seeing this error?
Here is the certificates. Please try to install certificates.
https://internalca.autodesk.com/certsrv/
https://knowledge.symantec.com/support/ssl-certificates-support/index?page=content&id=so4785
If it’s for signed applications, they need https://knowledge.symantec.com/support/ssl-certificates-support/index?page=content&actp=CROSSLINK&id...
If it's for SSL they need: https://knowledge.symantec.com/support/ssl-certificates-support/index?page=content&actp=CROSSLINK&id...
 Need to download the root certificates and import them into Keystore. Double clicking the certificates on windows start the import.
After installation of certificates then try below steps and then try to install the update.
  • Restart ADA.
Srinivas.
Message 11 of 16
Hotter_R
Autodesk Support
Autodesk Support
Hello scarta!
Have you already tried to uninstall and reinstall the Desktop App?
Install Autodesk Desktop App
Please try this first.
Here is an overview for the certificates needed for Autodesk software:
Issued To
Issued By
Remarks
Download link
Baltimore CyberTrust Root
direct download
https://www.digicert.com/CACerts/BaltimoreCyberTrustRoot.crt
GeoTrust Global CA
GeoTrust Global CA
save link as GeoTrust Global CA.crt
https://www.geotrust.com/resources/root_certificates/certificates/GeoTrust_Global_CA.pem
GlobalSign
GlobalSign
direct download
https://secure.globalsign.net/cacert/Root-R1.crt
GlobalSign Root CA
GlobalSign Root CA
direct download
https://secure.globalsign.net/cacert/Root-R3.crt
Starfield Class 2 Certification Authority
direct download
http://certificates.starfieldtech.com/repository/root.crl
Thawte Timestamping CA
download available on this Site
https://search.thawte.com/support/ssl-digital-certificates/index?page=content&id=SO9699&actp=search&...
VeriSign Class 3 Public Primary Certification Authority - G5
save link as VeriSign_Class_3.crt
https://www.symantec.com/content/dam/symantec/docs/other-resources/verisign-class-3-public-primary-c...
VeriSign Universal Root Certification Authority
save link as VeriSign_Root.crt
https://www.symantec.com/content/dam/symantec/docs/other-resources/verisign-universal-root-certifica...
These 8 certificates should be on your system.
Rainer Hotter
Technical Support Specialist - Installation & Licensing
Message 12 of 16
Yes I have unistalled  and reinstalled it many times.
All of certificates indicates are present on my PC.
I tried to click on https://internalca.autodesk.com/certsrv/ but I receive an error message: Unable to find DNS
Message 13 of 16
Hotter_R
Autodesk Support
Autodesk Support
Hello scarta,
as you wrote
This is a network configuration issue. The Browser is not able to resolve the URL to an IP Address, because he cannot find a DNS Server. Please check your network configuration or ask you company IT Admin for help to get this fixed.
Your first message:
can also be the result of network issue. If the downloaded files are corrupt or not fully downloaded you also can get such a message.
Please give us a feedback about your network configuration and if you or your IT Admin could fix the network problem.
Rainer Hotter
Message 14 of 16
Hotter_R
Autodesk Support
Autodesk Support
@Anonymous
Can you please give us an Update of the issue?
Rainer Hotter
Message 15 of 16
I am waiting our IT for resolve the network problem.
Stefano
Message 16 of 16
Hotter_R
Autodesk Support
Autodesk Support
@Anonymous
Can you please accept my answer from 11-29-2017 08:36 AM as solution if the network repair by your IT fixes the issue. Otherwise please answer in the blog again.
Many thanks for that.
Rainer Hotter
