Autodesk Desktop App - The digital signature needed for this install can´t be ve
alexanderriis
alexanderriis
Anyone who has actually fixed this?
mdavis22569
HI @alexanderriis
Please review the following:
https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/The-digital-signature-ne...
You can also use the account manager for the download and installation if needed while trying to resolve this:
https://manage.autodesk.com/cep
Mike Davis
alexanderriis
I am aware of all the workarounds but an actual fix to get the desktop app to work Woolf be nice.
Is the problem really that autodesk dont or cant require digital signaturen from Microsoft for updates?
natasha.l
Hello @alexanderriis,
I will move this post to the Autodesk Desktop app forum for you, this is a product related issue so it is in the correct location for proper support.
Thank you.
Hello@alexanderriis,
Thanks for your feedback.
Could you please check that, do you have all the root certificates installed on your system or not?
Here is an overview for the certificates needed for Autodesk software:
Issued To
Issued By
Remarks
Download link
Baltimore CyberTrust Root
direct download
https://www.digicert.com/CACerts/BaltimoreCyberTrustRoot.crt
GeoTrust Global CA
GeoTrust Global CA
save link as GeoTrust Global CA.crt
https://www.geotrust.com/resources/root_certificates/certificates/GeoTrust_Global_CA.pem
GlobalSign
GlobalSign
direct download
https://secure.globalsign.net/cacert/Root-R1.crt
GlobalSign Root CA
GlobalSign Root CA
direct download
https://secure.globalsign.net/cacert/Root-R3.crt
Starfield Class 2 Certification Authority
direct download
http://certificates.starfieldtech.com/repository/root.crl
Thawte Timestamping CA
download available on this Site
https://search.thawte.com/support/ssl-digital-certificates/index?page=content&id=SO9699&actp=search&...
VeriSign Class 3 Public Primary Certification Authority - G5
save link as VeriSign_Class_3.crt
https://www.symantec.com/content/dam/symantec/docs/other-resources/verisign-class-3-public-primary-c...
VeriSign Universal Root Certification Authority
save link as VeriSign_Root.crt
https://www.symantec.com/content/dam/symantec/docs/other-resources/verisign-universal-root-certifica...
These 8 certificates should be on your system.
if you don't have,
Here is the certificates. Please try to install certificates.
https://internalca.autodesk.com/certsrv/
https://knowledge.symantec.com/support/ssl-certificates-support/index?page=content&id=so4785
If it’s for signed applications, they need https://knowledge.symantec.com/support/ssl-certificates-support/index?page=content&actp=CROSSLINK&id...
If it's for SSL they need: https://knowledge.symantec.com/support/ssl-certificates-support/index?page=content&actp=CROSSLINK&id...
 Need to download the root certificates and import them into Keystore. Double clicking the certificates on windows start the import.
After installation of certificates then try below steps and then try to install the update.
  • Exit ADA(from system tray menu)
  • Stop AdAppMgr Service (windows task manager)
  • %Programdata% > Autodesk > Delete the “SDS” folder
  • Restart ADA.
I would like to know more about the issue, could you please send me the log files?
Please find the attachment for log file instructions.
Srinivas.
