Activation Code reset ACAD 2018LT
Timboxx
Timboxx
We recently installed 2 seats of ACAD 2018 LT.
Unfortunately put in the wrong activation codes and now we need to reset completely.
The install worked fine and the programs work on trial mode a present.
Is there a way of clearing the activation process to allow the correct codes to activate correctly short of uninstalling and reinstalling?
Cheers
T
DarrenP
try this: https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Forcing-re-activation-of...
DarrenP
Timboxx
Hi tried this.
did not clear all the fields.
I could put in a serial number OK
the product key would not reset.
And there was no place for the activation code.
result the same. still does not work.
Received email conformation from autodesk of product activation, which it isn't. This must be automated response yes?
would reinstalling be the best?
T
natasha.l
Hello @Timboxx
Be sure you type in the Product Key. You only need a Serial # & Product Key to activate.
Autodesk AutoCAD LT 2018  Product Key: 057J1
Please note to activate:
  1. Depending on the download method it will automatically recognize your credentials & sign-in or you manually type in the serial# & product key (you shouldn't need an activation code)
  2. An internet connection is required to activate, every 30days you should be connected to the internet at some point (to verify your license & use the software) Adjust your proxy settings, to allow access during the install & first launch, also make sure you have an uninterrupted connection. You can try another Wifi network location
Please "Accept As Solution" to a reply or replies if it helps answer your question.
Timboxx
If we purchased 2 seats of ACAD 2018 LT at the same time, will these have the same serial number and key?
natasha.l
Hello @Timboxx
Yes, a Multi-Seat, Stand-Alone License allows you to use a single serial number and product key to run one or more Autodesk products on a specified number of computers.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
natasha.l
Hello @Timboxx,
Let us know if you have any more questions. Please remember to “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Thank you.
