If I click the Autodesk App int the tray, a square window opens. It is white with a blue spinning circle in the center. The circle never goes away and the app's interface does not appear.
My most recent install was Max 2018 Update 1.
Solved by srinivasarao.potla. Go to Solution.
Hello davision,
Thanks for your feedback.
Please try this
Still you have problem, please try this,
Srinivas.
Hi Davision,
It seems that your Autodesk Desktop Application installation has become corrupted.
Could you please try these steps:
Open the task manager and stop the AdAppMgr Service, under the services tab.
If this doesn't solve your issue you should reinstall the ADA:
Kristofer
