Autodesk Desktop App (Read-Only)
Welcome to the Autodesk Desktop App Forum. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Stuck at spinning circle -- interface never comes on
3 REPLIES 3
3535 Views, 3 Replies
If I click the Autodesk App int the tray, a square window opens. It is white with a blue spinning circle in the center.  The circle never goes away and the app's interface does not appear.
My most recent install was Max 2018 Update 1.
3 REPLIES 3
srinivasarao.potla
Hello davision,
Thanks for your feedback.
Please try this
  • Exit ADA
  • Stop AdAppMgr Service
  • %Programdata% > Autodesk > Delete the “SDS” folder
  • Restart ADA.
Still you have problem, please try this,
Srinivas.
kristofer.barros
Hi Davision,
It seems that your Autodesk Desktop Application installation has become corrupted.
Could you please try these steps:
  1. Exit the ADA from the system tray icon.
  2. Open the task manager and stop the AdAppMgr Service, under the services tab.
  3. Delete the SDS folder (C:\ProgramData\Autodesk\SDS).
If this doesn't solve your issue you should reinstall the ADA:
  2. Uninstall the ADA from the control panel.
  3. Install the latest ADA from this location: http://www.autodesk.com/ada-supportinstall
Kristofer
in reply to: srinivasarao.potla
Okay, thanks. The reinstall worked.
