Desktop app not showing updates
Message 1 of 18
Hi
is anyone having issues with the Autodesk Desktop App not showing clearly available updates, in particular with Inventor Professional 2018.
I have build 112 currently installed which has no service packs, however I am aware that service pack 2.3 is released. Is
I also have other Autodesk products installed and in the instance of AutoCAD 2017 this does show that there is a service pack update.
Is there are an offline installer page to get to service pack updates where the .msi's could be downloaded? I have used these recently to update Recap Pro?
Replies (17)
Message 2 of 18
pendean
Community Legend
Community Legend
Log out and back into the app: if no help, try this https://forums.autodesk.com/t5/autodesk-desktop-app/ad-desktop-app-showing-no-information/m-p/755925...
You can also get your updated from the UPDATES link at your Autodesk accounts page https://manage.autodesk.com/cep/#products-services/all
Message 3 of 18
srinivasarao.potla
Hi @Anonymous,
Thanks for the feedback.
Have you seen any update on Autodesk desktop app?
Have you activated the product?
could you please try this.
       Exit Autodesk desktop app(from system tray menu)
       Stop AdAppMgr Service(task manager)
      %Programdata% > Autodesk > Delete the “SDS” folder
       Restart Autodesk desktop app.
I would like to know more about the issue. could you please share the log files with me?
Please find the attachment for log file instructions.
Srinivas.
Message 4 of 18
Kevin.Spear
Hi. I have the same problem. Only the SDS folder no longer exists. I suspect that for 2019, ADA installs into a different folder. Thoughts?
Kevin
Kevin Spear, PE
Message 5 of 18
srinivasarao.potla
Hi@Kevin.Spear,
Thanks for your feedback.
If Autodesk desktop app runs properly then definitely there should be SDS folder.
I have some questions.
which product you installed?
have you installed the updates from accounts portal?
Autodesk desktop app have one feature, always install the latest product updates at the same time, did you tick the checkbox or not?
have you activated the product?
I would like to know more about the issue, could you please send me the log files?
Srinivas.
Message 6 of 18
Kevin.Spear
I have 15 products all installed from desktop app while I was signed in. I now that there are updates now. They do NOT show up when I am signed in. I sing out, ask the app to check for updates and then they appear. If I sign back in, they all disappear. If I ask to check for updates while signed in, it says there are no updates. I did all of this just now.
Kevin
Kevin Spear, PE
Message 7 of 18
Kevin.Spear
Sorry - heres the log. Only from SDS folder, nothing in other folder.
Kevin
Kevin Spear, PE
Message 8 of 18
Kevin.Spear
log file
Kevin
Kevin Spear, PE
Message 9 of 18
srinivasarao.potla
hi@Kevin.Spear,
Thanks for sharing the log files. the log files are not good. Please follow the instructions and log in autodesk desktop app and send me the log file.
You are saying, when you log out you are seeing updates and log in not seeing updates on Autodesk desktop app.
did you installed the products with same account?
Srinivas.
Message 10 of 18
Kevin.Spear
You are correct. When signed in - no updates. I sign out, right-click system tray icon to check for updates and they all come back.
See attached zip file for logs.
Kevin
Kevin Spear, PE
Message 11 of 18
kboschJGDNZ
I have the same problem. The desktop app never shows me any updates and it always says "Your available updates are installed". I had to hear of a college of mine that there was a hotfix for Revit (Revit 2018.3.1 Hotfix), but had to install it manually.
I've tried the steps above..
Message 12 of 18
srinivasarao.potla
Hi@kboschJGDN,
Srinivas.
Message 13 of 18
kboschJGDNZ
Hey
Sorry for the late reply, but hereby I send the log files.
Message 14 of 18
srinivasarao.potla
Dear kboschJGDNZ,
Log files shows that, you already installed the update(Revit 2018.3.1 Hotfix). so its already installed in client machine, it won't show up on Autodesk desktop app.
if you want to try to install from autodesk desktop app, uninstall the update, do a check now on autodeskdesktop app then you can see the update on Autodesk desktop app and then install from autodesk desktop app.
Hope this helps.
Regarsa,
Srinivas.
Message 15 of 18
wunnaphyoGBHBM
Community Visitor
Community Visitor
It's really work.
Thanks a lot.
Message 16 of 18
jamesmac1201
@lim.wendy, can I get some clarification on how to update my version of the Desktop App? I just installed Civil 3D 2021 and noticed there are no updates. I know there were a few updates, so I had our CAD Manager download and install them. Typically, the Desktop App shows any add-ons and updates.
Message 17 of 18
lim.wendy
Hi @jamesmac1201,
Thank you for reaching out. Please follow the instructions posted by @srinivasarao.potla. If you are still facing issues, please upload a copy of the log file.
Additionally, do note that the My Updates tab stops displaying if:
  • There are no more updates to install.
  • A communication error prevents updates from being delivered to your computer.
    To check for communication errors:
    1. On the system tray, right-clicklimwendy_0-1626310085958.png.
    2. On the shortcut menu, click Check now.
      If a communication error is detected, the Autodesk desktop app displays an error message.
You may want to try to uninstall and reinstall the Autodesk Desktop App. See How to clean uninstall and reinstall Autodesk Desktop App.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 18 of 18
jamesmac1201
I attached the log files and an image of how my Autodesk Desktop App looks. You'll notice that Civil 3D and Infraworks are not shown on the left side panel. Even if there are no updates, all loaded programs are typically shown on this panel.
Also of note, I performed a clean uninstall and reinstall (per instructions) of the app prior to creating the log files.
I have:
Civil 3D  2020, 2021
Revit 2018
Infraworks
Navisworks Freedom, Manage
Autodesk Recap
Autodesk Formit
