Announcements
IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
ADT Change Properties Box
7 REPLIES 7
Message 1 of 8
376 Views, 7 Replies
Anyone know of a system variable or setting somewhere in ADT that switches
on or off the extended properties display in the Change Properties dialog
box? I have a user that when he clicks on an ADT object he only gets a
limited amount of information in the change properties dialog box. Things
like clean up radius and such don't show up.
Any suggestions?
Dan
7 REPLIES 7
Message 2 of 8
Usually happens when more than 1 entity at a time is selected. The "lowest
common set" of properties are displayed. Have them try picking just 1 entity
and what happens?
Regards
Reid M. Addis
Addis Computer Consultants
1-800-841-4418
http://www.addiscomputer.com
raddis@addiscomputer.com
"Dan Cross" wrote in message
news:8CD3C814DAF7369EDA77F938B86F3AA6@in.WebX.maYIadrTaRb...
> Any suggestions?
> Thanks
> Dan
Message 3 of 8
The user is picking only one entity. The display only shows layer that the
object is on and a few other bits of information. I can't figure it out.
Dan
"Reid M. Addis" wrote in message
news:B1AC7EEE7426F6B945A25E4E9B8B5C6F@in.WebX.maYIadrTaRb...
entity
> and what happens?
> Regards
> Reid M. Addis
> 1-800-841-4418
switches
dialog
Things
> > Any suggestions?
> > Thanks
> > Dan
Message 4 of 8
Hmmm...I'm looking but am kinda clueless here. Try this: without anything
selected, open the Properties dialog box (ctrl+1). Do you have under the
Categorized tab sections for General, Plot style, View and Misc? Now select
a wall with the dialog box still open. After the picking the wall, all you
get is General? No Location, Style, Dimension?
Regards
Reid M. Addis
1-800-841-4418
news:A3847D2C997D77B032F74347135D8819@in.WebX.maYIadrTaRb...
the
> Dan
"lowest
> entity
> > and what happens?
> > Regards
> > Reid M. Addis
> > 1-800-841-4418
> switches
> dialog
a
> Things
> > > Any suggestions?
> > > Thanks
> > > Dan
Message 5 of 8
Yup, that's what I see. Exactly following your instructions below....I do
not show any location, style, or dimension...only general...
Wierd isn't it....
Dan
news:6BB652A0D31A10139C897C6387345704@in.WebX.maYIadrTaRb...
select
> Regards
> Reid M. Addis
> 1-800-841-4418
Message 6 of 8
You might check the Friday, August 03, 2001 10:53 AM posting by Tony from
Product Support.
chris yanchar
building industry division
autodesk, inc.
news:F08A675426D51D5866C5734E72458531@in.WebX.maYIadrTaRb...
> Wierd isn't it....
> Dan
Message 7 of 8
Ahem,
For those too lazy to cut and paste (not you Chris), here's the content
of that message:
"There is a rare problem in which invalid entries in the registry leads to
the Object Properties Manager returning "No Selection".
Unfortunately, there isn't an automated fix for this problem and the best
suggestion I can provide is a complete uninstall and
reinstall. In this case, I would highly recommend removing all Autodesk
products from this machine, removing all Autodesk files and
registry entries and then reinstalling Arch Desktop 3.3. This process
should help to ensure that you have a clean install. For
details on this process, you can visit the following web page:
http://support.autodesk.com/getdoc.asp?id=TS45252
Tony
Discussion Moderator
WW Support & Services, Autodesk
Discussion Q&A: http://discussion.autodesk.com"
Regards
Reid M. Addis / Addis Computer Consultants
phone: 1-800-841-4418 fax: 1-610-668-8828
web site: http://www.addiscomputer.com
e-mail: raddis@addiscomputer.com
"chris yanchar - autodesk" wrote in
message news:0AD19CC69F5873ACAE4EB3526039CC55@in.WebX.maYIadrTaRb...
> Product Support.
> chris yanchar
> autodesk, inc.
do
> > Wierd isn't it....
> > Dan
Message 8 of 8
Does the object properties dialog work when you have normal AutoCAD
entitites selected? So if you select a line, do you see the start and end
point information listed in the OP dialog? If not, have you checked
PICKFIRST? Make sure its 1.
If normal AutoCAD entities work, are you using ADT or the object enabler for
ADT? If you are using ADT, then it sounds like a problem in your registry.
Have you tried reinstalling?
-scott
> Wierd isn't it....
> Dan
anything
> select
you
> > Regards
> > Reid M. Addis
> > 1-800-841-4418
