Jarod,
I tried that solution and it didn't work. Any other ideas?
"Jarod J. Schultz" wrote in message
news:BA34809590F68AF9888A97980CFBA9C5@in.WebX.maYIadrTaRb...
> Look to see if layer Zero is Off or Frozen. Thaw or Turn Layer Zero back
On.
> This should fix it. This is a Known Issue....
> Jarod J. Schultz, Vice President - Training
> Autodesk ATC Executive Committee Member
> http://www.CAD-1.com - Jarod.Schultz@CAD-1.com
> Premier Autodesk Training, Support and System Center
> 12130 N. Pennsylvania St., Suite 101
> Denver, Colo. 80241
> Ph. 303-427-CAD1
> Fax. 303-428-9729
> "Brian F." wrote in message
> news:7FC1CFEAAFB69FE448F1EE752126FD0E@in.WebX.maYIadrTaRb...
> > My office is having a huge problem with ADT 3.0 and 3.3. Chairs brought
> in
> > from the Design Center are disappearing within drawings.
> > Here are the steps to create the problem:
> > 1. Open a new drawing.
> > 2. Drop in chairs from the design center.
> > 3. Isolate the layer the chairs are on(a-furn).
> > 4. Move the chairs.
> > Then they disappear. Undo doesn't bring them back into the display.
Nor
> > does regen.
> > Typical System info:
> > PIII 1gig
> > 32 mg Graph. Card (withh accel. turned off)
> > 512 Ram
> > 20 Gig HD w/ 17 gig free
> > Win 98 se
> > ADT 3.0 sp 2 and 3 (happens on both sp's)
> > or ADT 3.3
> > What is going on? This is a big problem for us.
