Jacketed Piping Systems
Can have Autodesk add to Plant 3D a tool or method to add Jacketed Piping Systems.
  • Parametric to allow either:
    • Full pipe,
    • different start & end offsets,
    • weld/end caps types at ends.
    • different pipe spec and materials
    • etc
  • Recognised during Isometric generations.
  • Be able to choose which pipe when:
    • joining other pipes
    • adding bleed pipes or valves,
    • plugs and nipples.
7 Comments
h_eger
Dear @Anonymous,
Once you have an International or National Standard for Jacketed Piping Systems on Autodesk, the content team will be responsible for creating such a catalog.
If autodesk can make the python scripts for jacketed components, then user can create the fittings according his inputs.
h_eger
No Autodesk does not change the Python user scripting as there is no standard for jacketed pipes
manas_x
That's no excuse, Bentley has had it sorted out for years.
Eso no es excusa, Bentley lo tiene resuelto hace años.
h_eger
Dear @manas_x ,
Autodesk is not Bentley.
Autodesk has different guidelines for these tasks.
So good luck with Bentley
manas_x
Autodesk is not Bentley...obvious.
But it could do something. Even if no details are given.
I don't think that's asking too much.
Just my opinion.
Autodesk no es Bentley...Obvio.
Pero podría hacer algo. Aunque no se indiquen detalles.
No creo que sea pedir demasiado.
Es mi opinion.
h_eger
You can contact Autodesk directly and make your suggestion. As long as there are only 44 approvals here, the development team will not take on this task. With 250 votes in favour, it looks quite different again.
