IFC Import & Export from Plant 3D
Import & Export IFC Files from Plant 3D.
53 Comments
davidjonssonfvb
this is a critical feature for us!
We are always working together with other diciplines and sharing data between softwares and BIM-coordination.
Our solution at the time is to open the Plant 3D in Civil 3D and make the IFC Export from there, not a great solution.
Regards David and FVB Sweden
This is needed to collaborate within the AEC collection.
A must have !
norbert_palumbo
BIM project in 2021 no BIM for piping.
BIM and Process still not compatible ?
hlammerts
davidjonssonfvb
Is it here yet?
m.bevers
@davidjonssonfvb; This request has been made Juli 2015. That's only 6 years ago mate.
This is Autodesk, we're talking about.. They need time
@hlammerts; Thanks for sharing, but to me it'd make more sense if this function were to be implemented within AutoCAD (or any of the Autodesk programs for that matter)
norbert_palumbo
It's been a long time ...
The integration with Revit is not yet developed and the gateway does not seem very smooth to me, going through a web interface to link the PIDs and the piping.
This also does not assure us of an IFC export of Plant 3D files.
damirzukic
Community Visitor
Hi Everyone,
Please advise on best IFC file viewer or software !  I have a piping model with steelstructure to be able to view.
File is 667.000,00kB big.
Thank you,....
pieter.vandeweerd
I would propose to use BIMvision: https://bimvision.eu/
Loading a model this size would take a minute or two but once it is open, navigating goes quite smooth.
Rgds,
Pieter
damirzukic
Community Visitor
Thank you Pieter,
I'll give it a try and let you know if it worked!?
norbert_palumbo
Trimble Connect is also a good IFC file viewer.
However, you have to register on the site.
Trimble Connect For Windows | Tekla Download
Rgdts,
Norbert
joachim.o
Almost 7 years later and IFC export is still not available...
norbert_palumbo
As a reminder, BIM is always defined in relation to building and civil engineering.
The latest ISO 19650-1 to 4 standards are called :
Organization and digitization of information about buildings and civil engineering works, including building information modelling (BIM).
The Process is not the priority of REVIT or other Civil software.
PIM is not on the agenda (Process Information Modelling)
The integration of Plan 3D in Revit is always laborious due to the notion of piping networks in a building and the notion of piping lines and isometrics of Piping software.
joshua_jones2
We need Plant 3D to be BIM Level 2 compliant and be able to produce IFC and COBie for integrations with Enterprise Asset Management Systems like Maximo.
norbert_palumbo
a plugin to test
BIM Data Exchange(BXF) | CAD-BIM Interoperability Solutions (bimdex.com)
AutoCAD Plant 3D to Revit Exporter | Importer, Converter, plug-in, add-on, Tools (bimdex.com)
How AutoCAD Plant 3D models Imported in Revit? ​
  • Export your Plant 3D model (.dwg) as a BXF file using our Plant 3D Exporter plugin.
  • The Exported BXF file contains all the design data information along with the model properties/metadata.
  • Import the BXF file inside Revit using the Revit Importer Plugin to obtain native Revit Projects (.rvt) and families (.rfa)
  • BIMDeX automatically categorizes the Plant 3D components such as Pipes, Pipe Fittings, Pipe Accessories, Equipments, Structural Elements, etc. which are mapped to their corresponding categories in Revit.​
  • BIMDeX plugin also provides a lot of other customizable options for the user during Export & Import, to obtain the desirable output.
  • Supported Langauges:
    English, Spanish, French, German, Italian
  • Supported Version:
    Revit: 2016 - 2022
    AutoCAD Plant 3D: 2017 - 2022
M-BRF
IFC export / import is a must have.
michael_broennimann
Hi
Minimum is IFC export to share with customer. But both would be nice like it works on ACA or Navisworks.
- Geometry is a must Attributes would be nice
Regards
Michael
udo_hoffmann
2024-10-18 Udo Hoffmann
Hello Plant 3D community,
IFC and Plant 3D is here in discussion from year 2015 nearly 10 ! years.
To exchange BIM conform 3D models with an overall Customer-BIM-coordination
project a data consistency is crucial - for building and also for equipment / plants / HVAC
deliverer. There is an exporter available from Codemill.
Codemill IFC Export for Autodesk® AutoCAD® Plant3D | AutoCAD Plant 3D | Autodesk App Store )
IFC is at the moment the best available standard for exchange 3D-models and data.
dylan.berryF2V25
This is SO important and needed! Please
John_ODoherty1
Community Visitor
Essential
