Copy/Paste 3D line with TAG
Possibility for Coy and Paste 3D pipe routing without loose TAG of Pipe Line Group. It's very important if is necessary to change location of any pipe from one dwg to another.
3 Comments
Hermann.Semlitsch
i would also prefer this function but this should include the PID too.
because it is alwas time expansive to copy full streams in PID and 3D. because the only difference is the TAG. and when you have e.g. 5 same streams, you wil lsit a long time to copy this...
it would be also great if there is a possibility to link this stream. it is also time expansive to make changes on same streams.
so. i would prefer a minimum function called: paste with new TAGs and a window should come where you can change/see the new/old TAG.
this will save time!
dave.wolfe
This should apply to all line group data (service, nominal size/spec) in P&ID and Plant 3D. Very rarely (ever?) do we want to copy lines and lose the data.
Vicky.Wu
