Show Pipe length in Metric in an Imperial Project
lplourdeV9N9F
lplourdeV9N9F
I have an imperial project, and in the Isometrics I want to display the pipe sizes (diameter) in inches but display the length of the pipe in metric. I don't want to change any units in the 3D model, just in the isometrics.
h_eger
Dear @lplourdeV9N9F ,
Unfortunately, this function is not supported by Plant 3D.
For your project you should create the projects in Mixed Metric so that it works.
Changing the project details later on can destroy the project.
https://knowledge.autodesk.com/de/support/autocad-plant-3d/learn-explore/caas/sfdcarticles/sfdcartic...
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
lplourdeV9N9F
Thanks for the reply. That was what I was afraid of. Would it be easy for me to copy the entire project to a new project to be able to select mixed metric? Can I keep everything else in my project directory like templates?
DVaquand
Hello
Sorry for my English, which I don't speak and whose post has been translated with google Translator
Here is an approach to output isometrics in MM units from a project defined in INCH.
For that I created a new iso style "Final_ANSI-C metric" which is the copy of the style "Final_ANSI-C"
In this new style I modified the "IsoConfig.xml" file to apply the MM parameters for the nomenclature and coordinates part
In the "Iso.dwt" file I modified the "AdskIsoImperial" dimension style to apply a metric dimensional unit and a unit scale factor of 25.4 to it.
This setting is only an approach which may require some readjustment.
See Screecast
I attach the file of the iso style "Final_ANSI-C metrique" which is in French.
== French ==
Bonjour
Voici une approche pour sortir des isométriques en unités MM depuis un projet défini en INCH.
Pour cela j'ai créé un nouveau style iso "Final_ANSI-C metrique" qui est la copie du style "Final_ANSI-C"
Dans ce nouveau style j'ai modifié le fichier "IsoConfig.xml" pour lui appliquer les paramètres MM pour la partie nomenclature et coordonnées
Dans le fichier "Iso.dwt" j'ai modifié le style de cote "AdskIsoImperial" pour lui appliquer une unité dimensionnelle métrique et un facteur d'échelle d'unité de 25.4.
Ce paramétrage n'est qu'une approche qui nécessitera petu-être quelques réajustement.
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
lplourdeV9N9F
Thanks! This is pretty much what I ended up figuring out myself. Glad to know it wasn't completely insane. Now I know the proper way is to verify the units right at the beginning of the project but this will work for now just to fix a few drawings.
