Guys,
Is it possible to select which stub end description I want?. I need a different description for a stub end that connects to a butterfly valve.
Cheers
Solved by MateusMaciel. Go to Solution.
Select the component using the CTRL button, you will see that the selection will be yellow, then click the arrow to select the other option, just like you did.
