AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Select different type of Stub End
2 REPLIES 2
Mauricio_DM
706 Views, 2 Replies
Guys,
Is it possible to select which stub end description I want?. I need a different description for a stub end that connects to a butterfly valve.
Cheers
2 REPLIES 2
MateusMaciel
in reply to: Mauricio_DM
Select the component using the CTRL button, you will see that the selection will be yellow, then click the arrow to select the other option, just like you did.
mateustilapa@gmail.com
Thanks!
