Same component showing multiple times in tool palette
santoshbaraiya
santoshbaraiya
In my project same component is shown 2 times in the tool palette. Is there any way to remove the duplicating component from tool palette?
Tomislav.Golubovic
What's the spec look like?
quan_hm
That is likely due to these components have different family name, just make sure these have same family and it will only show once.
Hoang Minh Quan - Piping design engineer
Autodesk Store for Python Catalog
h_eger
@santoshbaraiya ,
In P3D 2025 you can set this so that there are no more duplications
https://help.autodesk.com/view/PLNT3D/2025/ENU/?guid=GUID-C251B3C0-F885-4BC8-9D6B-A467D9C995F7
https://help.autodesk.com/view/PLNT3D/2025/ENU/?guid=GUID-178AC4EC-8245-4996-A2B4-431DE6BA592A
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
km4504
Question was for Tool Palette, not Spec Viewer.
If my reply was helpful, please give a Kudos or click the Accept as Solution button below (or both).
santoshbaraiya
I figured out. In a particular pipe component has different ITEM CODE written. After making same ITEM CODE for all sizes, that issue was resolved.
Earlier first pipe has some item code written. after clearing that issue is gone
