Message 1 of 8
Hello everyone,
Is it possible to output the P3D class in the report creator?
Hello everyone,
Yes, if you select "EngineeringItems_PartCategory" from the "Field list"
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Hallo @jflorita ,
what should you have overlooked?
All Plant 3D classes are entered in the first column.
There is no more information about the Plant 3D classes.
Hartmut Eger
Senior Engineer
XING | LinkedIn
I see, what I wanted was the specific type (elbow, tee, etc.). Ill just use the description and remove the unnecessary texts. Thank you
these objects all run under fittings (elbow, tee, etc.)
Hartmut Eger
Senior Engineer
XING | LinkedIn
Sharing this to everyone.
I found a way to include the P3D Class in my report.
I created a calculated property and added PnPClassName.
In the report creator, you will see the property you created and now you're good.
Hi!
I'm coming from this post: https://forums.autodesk.com/t5/autocad-plant-3d-forum/how-to-make-report-creator-output-a-table-iden...
Works for me too!
Thanks for sharing.
