AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Report Creator: Output P3D Class
6 REPLIES 6
jflorita
240 Views, 6 Replies
Hello everyone,
Is it possible to output the P3D class in the report creator?
Labels (1)
6 REPLIES 6
h_eger
in reply to: jflorita
@jflorita ,
Yes, if you select "EngineeringItems_PartCategory" from the "Field list"
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
jflorita
in reply to: h_eger
Hello @h_eger
I already tried that and this was the output, maybe I'm missing something?
h_eger
Hallo @jflorita ,
what should you have overlooked?
All Plant 3D classes are entered in the first column.
There is no more information about the Plant 3D classes.
Hartmut Eger
Senior Engineer
XING | LinkedIn
jflorita
in reply to: h_eger
I see, what I wanted was the specific type (elbow, tee, etc.). Ill just use the description and remove the unnecessary texts. Thank you
h_eger
these objects all run under fittings (elbow, tee, etc.)
Hartmut Eger
Senior Engineer
XING | LinkedIn
jflorita
Sharing this to everyone.
I found a way to include the P3D Class in my report.
I created a calculated property and added PnPClassName.
In the report creator, you will see the property you created and now you're good.
Technology Administrators
AutoCAD Beta
