AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
HOW CAN I LOCK PIPING LINE WITH COMPONENAT (LINE LOCK)
3 REPLIES 3
yogesh_sankpal3WAHJ
169 Views, 3 Replies
I WANT TO LOCK MY ROUTED PIPE LINES & ONLY OPTION IS
LOCK/ UNLOCK PLACEMENT but this option locked only placement, i want to restrict modifications in routed pipe
can we lock all lines to restricts modification & placement??
any other option please suggest
Thanks in advanced
3 REPLIES 3
When you create a pipe with line number, it creates a layer for that line number.
You can lock that layer.
In the data manager, you can lock a pipe line as well.
I suggest doing this as this is the most appropriate solution.
I only use the layer locking when Im still working on the drawing, when Im finish I lock it in the data manager.
thanks so much for valuable support
