Break Point On Isometric Drawing Generation
InnoChigudu_
InnoChigudu_
I have been facing this Problem for  a while now. When I use manual Break Point on Flange Connections it Splits Iso into 3 instead of 2 Isos. The one will just the the Gasket and Bolts. I have tried snapping one end of Flange on using node snap but still doesn't work. I remove the Break Point the Iso is not split and becomes congested.
Anyone who knows how this one error is fixed?
h_eger
@InnoChigudu_ ,
Do not place the break pin directly on the flange side but inside the flange closer to the flange facing.
This works for me.
12-06-2024_08-09-34.mp4
Video Player is loading.
Current Time 0:00
Duration 0:00
Loaded: 0%
Stream Type LIVE
Remaining Time 0:00
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • en (Main), selected
    (view in My Videos)
    If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
    Hartmut Eger
    Senior Engineer
    Anlagenplanung + Elektotechnik
    XING | LinkedIn
    uk96710
    Hi @InnoChigudu_
    As @h_eger its right. But you can also delete the both flanges and readd them that will work..
    Let me know if it works.
    Umarfarukh
    Type a product name
