Hello everyone,
On report creator 2023, I have an error message when I tried to have a list of Gasket and BoltSet.
6 months ago, I was getting there and not anymore.
A error message :
I tried on report creator 2025, I tried to change a description, I tried wih an other gasket and bolt,...
How can I have a format type of 32 bits ? Could you help me ?
The detailed error message:
Type: Autodesk.ProcessPower.ReportCreator.ReportCreatorException
Message: Une erreur s'est produite lors de l'interrogation de données depuis la base de données.
Détails de l'erreur: The input string 'JOINT SUPRANITE PGAC 2 mm' was not in a correct format.Couldn't store <JOINT SUPRANITE PGAC 2 mm> in DescFamFastener Column. Expected type is Int32.
Stack trace:
at Autodesk.ProcessPower.ReportCreator.Manager.GetQueryData(QueryDefinition queryDef, Collection`1 dwgs)
at Autodesk.ProcessPower.ReportCreator.Manager.GetCurrentReportData()
at Autodesk.ProcessPower.ReportCreator.Manager.Print()
at Autodesk.ProcessPower.ReportCreator.MainForm.Print()
Inner exception:
Type: Autodesk.ProcessPower.ReportCreatorUtils.ReportCreatorUtilsException
Stack trace:
at Autodesk.ProcessPower.ReportCreatorUtils.Database.MultiClassDataView.GetDataTable()
Inner exception:
Type: System.ArgumentException
Message: The input string 'JOINT SUPRANITE PGAC 2 mm' was not in a correct format.Couldn't store <JOINT SUPRANITE PGAC 2 mm> in DescFamFastener Column. Expected type is Int32.
Stack trace:
at System.Data.DataColumn.set_Item(Int32 record, Object value)
at System.Data.DataRow.set_Item(DataColumn column, Object value)
at Autodesk.ProcessPower.ReportCreatorUtils.Database.DataView.GetDataTableInternal(PnPDataView pnpDataView, Boolean includeAllColumns, StringCollection selectedColumns)
at Autodesk.ProcessPower.ReportCreatorUtils.Database.DataView.GetDataTable(PnPDataView pnpDataView, Boolean includeAllColumns)
Inner exception:
Type: System.FormatException
Stack trace:
at System.Number.ThrowFormatException[TChar](ReadOnlySpan`1 value)
at System.String.System.IConvertible.ToInt32(IFormatProvider provider)
at System.Data.Common.Int32Storage.Set(Int32 record, Object value)
Sincerely,
Pierre.
