AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Amount Bolts incorrect while connecting compensator with two flanges
9 REPLIES 9
Message 1 of 10
fahmi_audishNMWLM
261 Views, 9 Replies
Good day,
When I connect flanges to compensator I only get the bolts on one side and not on both sides.
9 REPLIES 9
Message 2 of 10
h_eger
in reply to: fahmi_audishNMWLM
@fahmi_audishNMWLM ,
which Endcode did you use for your expansion joints? WF or FL
WF = intermediate flanged and has through bolts to both flanges
FL = end flange each flange connection gets a bolt set
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 10
fahmi_audishNMWLM
in reply to: h_eger
Because the compensator has already gasket I made a new end type (CWOG = connection without gasket) and I put it in the project setup.
Message 4 of 10
h_eger
Please show me once about "PLANTENDCODES" and Modify... your "CWOG" settings
e.g.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 5 of 10
fahmi_audishNMWLM
in reply to: h_eger
I do not use Wafer connection,I use only WN flange and LAP-joint flange.
Message 6 of 10
fahmi_audishNMWLM
in reply to: h_eger
I want to connect the expansion joint without gasket.
Message 7 of 10
h_eger
I read the words but I need the Endcode setting from CWOG!
as described above!
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 8 of 10
fahmi_audishNMWLM
in reply to: h_eger
Here is my Endcode CWOG.
Message 9 of 10
h_eger
your Endcode CWOG is set to "Wafer like" so there is only one bolt set.
This setting makes little sense for compensators as the bolt set restricts the freedom of movement.
I would also go for "Flange like" so that you get a bolt set at each end of your compensator.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 10 of 10
fahmi_audishNMWLM
in reply to: h_eger
I adjusted it and it worked.
Thank you very much for the help and the quick responses.
Greeting,
Technology Administrators
