PLANT 3D ORTHOGRAPHIC DRAWING PLANTORTHOANNOTATE BY COMMAND LINE
Good Day..
Looking for help in LISP coding to place all tag number of pipe support in orthographic view.
(defun c:BOP (/)
(command "PLANTORTHOANNOTATE" pause "Bottom of Pipe [BOP]")
(princ))
i am using this command but for next support again press Enter i wanted to skip this Enter and Place My Tag Any where as per My choice and Lets Continue the command for Next Support Tag
i am using like this
(defun c:SUPPLY (/)
(command "PLANTORTHOANNOTATE" pause "Support Annotation [Tag]" pause "Support Annotation [Tag]")
(princ))
but its happen like this
Command: SUPPLY
PLANTORTHOANNOTATE
Command:
Select a component to annotate:
Specify annotation style or [?] <Support Annotation [Tag]>: Support Annotation [Tag]
Specify annotation position [Rotate/disableLeader]:
Select a component to annotate: Support Annotation [Tag]
*Invalid selection*
Expects a point or Window/Last/Crossing/BOX/ALL/Fence/WPolygon/CPolygon/Group/Previous/AUto
; error: Function cancelled
Your help in this highly appreciated.
Regards
Sachin
h_eger
Dear @Anonymous,
This function is not programmable with LISP!
Please use AutoCAD Plant 3D SDK for programming
https://www.autodesk.com/developer-network/platform-technologies/autocad-p-id-and-plant-3d
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
jabowabo
(defun c:repeatTag (/)
	(while t
		(command "PLANTORTHOANNOTATE" pause "Support Annotation [Tag]" pause "")
(princ))
Thanks to replay on my problem i appreciate your help .
once again thanks.
jusea
Hello !
Thank you for your advice to the «PLANTORTHOANNOTATE»LISP
CODE:
(while t
(princ))
If I chose the "SUPPORTS" everything is OK, but if by chance I chose “Valve” or “Pipes”, then Lisp will stop the response (freezing).Please tell me how to change the LISP text.
jabowabo
The problem is that the LISP code is sending the command specific for support tag annotation. If you want to modify it to annotate other objects, you need to differentiate them and send the appropriate command. See below for an example that is conditional on the layer names - you will need to change the PLANTORTHOANNOTATE command parameter and/or layer names to suit your needs.
; [email protected];
(defun c:OrthoTagRepeat (/ e elay)
	(while t
		(if
			(and
				(setq e (car (entsel "\nSelect entity to tag: ")))
			(progn
				(setq elay (strcase(cdr (assoc 8 (entget e)))))
				(cond
						(wcmatch elay "*SUPPORTS*")
							(progn
								(command "PLANTORTHOANNOTATE" e "Support Annotation [Tag]" pause "")
								(command "mspace")
						(wcmatch elay "*PIPING*")
							(progn
								(command "PLANTORTHOANNOTATE" e "Nominal Size [Size]" pause "")
								(command "mspace")
(princ)
jusea
Jabowado
Thanks you.
Your code is working !!!
