Hello!
I have created a new connection type (PL_SP) and then have created a new pipe family with this type (by dublication PL connection pipe). It works almost well. But I've faced with one problem. When I have routed pipe and then change its size (by prorerties palett) I get an error with detail connection - so all the substituted parts are not connected. But when I use the Connect Component to Adjacent command all parts become connected. So why details can't be connected immediately after the replacement?
I can't understand a reason of this error. To reconnect all parts is very long. Please help me.
Please watch the little screencast about this error. Sorry, I couldn't record audio with my comments.
Thanks in advance.
Revise in spec editor, priority of elbows. There are yellow exclamation. It's necessary to change it to green circle, accepting priority (between elbow 45º and 90º for example)
Hello @Dan.Scales
Yes, I have attached the Test project in rar. Please check it.
Edited by request
Discussion_Admin
Hi @Artem_Marinin,
This disconnect is occurring because of the custom pipe end type "PL_SP". It seems that something is hard coded that requires the pipes to have the end type of PL.
I have logged this with our developers.
In the meantime you will either need to manually reconnect the bends or use the PL end type for the pipes.
Dan
