Hi all
I am having problems with the creation of Orthographic drawings in Plant 3D 2015.
The error message above is presented whenever a select Create Ortho View and Create New option is used.
If I try to create a new ortho view but add it to an existing ortho drawing it works fine.
Anyone seen this and have a solution please?
Phil
Solved by Phil. Go to Solution.
OK guys (and gals)
This looks like a user or admin error somewhere! I looked at the template drawing that the Ortho dialog was looking for and it didn't exist.
Methinks someone has renamed the template (which is in a server location), so the various projects I have with the old template referenced fall over when the Ortho command is run.
Phil
