P&ID Symbol List, AutoCAD Plant 3D 2027
mario_biasi_athenagroupsrl
Message 1 of 14
Hi everyone,
I am trying to create a "symbol list" type parameter for a P&ID instrumentation symbol.
I have created the parameter and associated the symbol with the list option, but the symbol does not display the list of options in the drawing, and the configuration is not being saved in AutoCAD Plant 3D.
Can anyone help me?
Many thanks.
Accepted solutions (3)
Replies (13)
Message 2 of 14
Tomislav.Golubovic
How did you make this "symbol list"?
Message 3 of 14
lauri_barnhart
Hello, @mario_biasi_athenagroupsrl.
Just following up to see if you saw the outstanding question posed by Tomislav.Golubovic. Please provide an update to answer the outstanding question and if you still require assistance.
Lauri | Community Manager
Message 4 of 14
Hi @Tomislav.Golubovic,
I created a new parameter associated with the class I was interested in and selected the "symbol list" option for the parameter type.
Next, for that same class, I created the blocks and then the symbols I wanted to associate with it.
Finally, I modified the "symbol list" parameter associated with each of the three values—which correspond to the symbols loaded into the class—so that they would appear as options.
I have followed this procedure with various other symbols before and never encountered any issues.
In what sense do you want to know how I created this symbol list?
Message 5 of 14
Hi @lauri_barnhart
I activate the notify, but I don't receive the email.
I don't know why.
Message 6 of 14
DVaquand
Hello @mario_biasi_athenagroupsrl
I noticed that for P&ID classes, the symbol list would not work unless the "Normally" property was included.
For Plant 2027, the 2027.1 update is available via the portal:
www.autodesk.com/account
I used the "Magnetic" symbol as an example.
== French ==
J'ai constaté, au niveau des classes P&ID, que dans la liste des symboles si on n'appeler pas la propriété "Normaly", la liste ne fonctionnait pas.
Pour la version Plant 2027, un mise à jour 2027.1 est disponible depuis le portail
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
Message 7 of 14
Hi @DVaquand,
Thanks for the reply.
I'll try your solution now and post here if I've solved the problem.
Thanks.
Mario Biasi
Message 8 of 14
Hi @DVaquand ,
I'have tried redefine the parameter and symbol list, but it don't work, even if I've installed the 2027.1 version of AutoCAD Plant 3D.
In the parameter's lista I don't have "Normally" parameter.
Please see the attached video.
Thanks.
Mario Biasi
Message 9 of 14
DVaquand
You must add this property manually because it does not exist by defaul
== French ==
Il faut ajouter manuellement cette propriété car elle n'existe pas par défaut.
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Message 10 of 14
lauri_barnhart
Just following up to see if the information provided by DVaquand provided the information you needed to resolve your issue? If it did, please consider clicking on the 'Accept Solution' button. If you still need assistance, please provide an update here.
Best,
Message 11 of 14
Hi @DVaquand,
sorry for the late of my answer.
I've tried add Normally parameter as a Symbo List, but the result is the same.
When I use the symbol, changing selected option of Normally parameter don't match with the associated block.
See the attached video.
Thanks.
Mario Biasi.
Message 12 of 14
DVaquand
Write "Normaly" with a single "l"
== French ==
Ecrire "Normaly" avec un seul "l"
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Message 13 of 14
lauri_barnhart
Hi, @mario_biasi_athenagroupsrl.
Just checking in to make sure that the additional information provided by DVaquand answered your question. Please let us know if the problem is resolved and working as expected. If you are still needing assistance, please provide an update here.
Message 14 of 14
Hi @DVaquand
sorry for the late of my message.
I tried with Normay but it's not working. ☹️
