AutoCAD Plant 3D Forum
moving equipment in Sample Project
9 REPLIES 9
Message 1 of 10
593 Views, 9 Replies
Hello everyone,
I'm using Sample Project and for some practicing purposes, I'm trying to 'move' or 'Copy' equioment's, but it is not possible!
I'm not sure why it acts like it is ina 'read-only' mode (and it shows a 'locked' symbol beside the name of the file on the 'Project Mnager' tab).
I'd appreciate if someone could help me in this case.
Behrouz
9 REPLIES 9
Message 2 of 10
h_eger
Plant 3D 20??
OS Version
Admin Rights?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 10
jabowabo
Did you open the file from the project manager? Plant 3D requires files to be open in project context for editing.
Message 4 of 10
in reply to: h_eger
Hello Hartmut,
Thanks for that.
it is Plant 3D 2014.
Windows 7, 64 bit
Admin of the computer.
Behrouz
Message 5 of 10
in reply to: jabowabo
Thanks for that.
Unfortunately I couldn't open it through Project Manager as it opens a file with nothing inside it. So I had to manually find the file and open it.
Is there any way I can solve this issue and open the file directly from Project Manager?
Thank you so much in advance.
Behrouz
Message 6 of 10
jabowabo
Are you certain the file in project manager is the same one you are opening manually? Check the path shown in proj mgr - the panel below the file tree. The tree structure does not necessarily reflect your windows folder structure, which can be quite confusing. In any case, you cannot modify items unless the file is open in project context.
Message 7 of 10
Thanks for that and  sorry for this delay.
I checked that, they are in the same path. But when I try to open the file from the Plant 3D itself, it doesn't show anything!
Thanks again.
Behrouz
Message 8 of 10
Thanks for that.
Yes, they are in the same path. When I open it from the 'project manager' it shows nothing. but I can open it manually by finding the file in the path.
Behrouz
Message 9 of 10
jabowabo
Remove the file showing in the project Mgr from the project (rt-click, remove) then copy the file you're opening (that has content) to the project (rt-click folder in project mgr and select 'copy dwg to project).
Message 10 of 10
jabowabo
That was a long delay btw!
Technology Administrators
AutoCAD Beta
