AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
More bigger than real
4 REPLIES 4
renan_limaY7LCF
162 Views, 4 Replies
Bom dia, amigos. preciso de ajuda...
cadastrei uma válvula globo angular e o tamanho dela ficou 25,4x maior que o real.
usei o comando "plantpartconverter" de um bloco de autocad.
podem me ajudar?
4 REPLIES 4
h_eger
in reply to: renan_limaY7LCF
@renan_limaY7LCF ,
Incorrect drawing units in:
the block for PLANTPARTCONVERT
in the drawing where the block was edited
In your Plant 3D Model
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
renan_limaY7LCF
in reply to: h_eger
Obrigado pela resposta, eu modifiquei para o tamanho correto para porem não funcionou
2,5"
Tags (1)
h_eger
Have you tested it in the Plant 3D project where the faulty component was inserted?
Create a new project and test it in it
Hartmut Eger
Senior Engineer
XING | LinkedIn
renan_limaY7LCF
in reply to: h_eger
thaks my friend
Technology Administrators
AutoCAD Beta
