How do I prevent spool isometrics to split at the branch of a tee or a stub-in?
Tom_Jipping
Tom_Jipping
I would like to create spool isometrics with the end points either being flanges or caps. For some reason my spool isometrics now also split at a branch of a tee and at a stub-in. As seen in the screenshot below; Surrounded in green is what I wish to accomplish (just 2 sheets), surrounded in red is what is generated at this moment (3 sheets).
Replies (7)
h_eger
@Tom_Jipping ,
It works for me as you have described.
Standard Iso Template Final_A2
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Chuck_Hackett
Usually when I want to force ISOGEN to a specific number of sheets, I will turn off the Automatic Drawing Congestion Splitting (uncheck... mine is currently checked). Then I will place an ISOGENSTARTPT at the beginning. Then place a STOPSIGN at the point where I want the first page to end. If you are only trying to generate two sheets, you only need one STOPSIGN. Everything prior to the stop goes on sheet one, everything after goes on sheet two.
If my answer got you moving forward, please mark it as the solution! (helps me build my nerd-credibility! 😉 )
Tom_Jipping
I see, and did you use any breakpoints at the flanged connection? Also, my wish is to just have a weld spool isometric. So nog boltsets or gaskets. Just a spool from 1 welded part to another (and in my example to 2 other end points). Is this possible?
Below are the results of the standard iso template Spool A3, this is exactly what I wish to see but it just cuts the spools in 2 at a Tee and there is no weld to be seen on either sheet.
Chuck_Hackett
Is the weld between the reducing tee and straight run a field weld? Have you allowed field welds to show up in your isometrics? Something is different between that weld and the rest. Start going through them and figure out why it's different, and if it needs to be different.
Tom_Jipping
All 3 welds are the same at the Tee. I think some setting is blocking branched connections (Tee, Stub-in) to be shown on a spool isometric.
Tom_Jipping
Well, with some correct terminology in the google (you need to be very specific with your word choices apparently) search bar I came across this older forum post;
https://forums.autodesk.com/t5/autocad-plant-3d-forum/spool-splitting/td-p/3841560
The first reply by @PeterQuinn gave me the solution. Setting the ''MaxDirectionChanges'' from 3 to 0 in the isoconfig.xml solved my problem.
Thanks @Chuck_Hackett and @h_eger for thinking along.
Chuck_Hackett
So a couple of things I'd check:
  • Again, the Automatic Split Points (personally I uncheck this when I want to control the split points, Picture 1)
  • Below that, same screen, make sure Split Drawing on Property Change is NOT checked (picture 1)
    • For grins, make sure none of the boxes below this one are checked (red square, picture 1)
  • Under Themes, Branch Piping... is it on? (top right, picture 2)
  • What size is it set up as? (picture 2)
  • Under Themes, Override... is it on? (top right, picture 3)
  • What size is it set on? (picture 3)
I'm not going to go through all of 'em, but I hope you get the point. Need to run through there and verify your settings.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
