Bom dia, amigos. preciso de ajuda...
cadastrei uma válvula globo angular e o tamanho dela ficou 25,4x maior que o real.
usei o comando "plantpartconverter" de um bloco de autocad.
podem me ajudar?
Solved by h_eger. Go to Solution.
Incorrect drawing units in:
the block for PLANTPARTCONVERT
in the drawing where the block was edited
In your Plant 3D Model
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Have you tested it in the Plant 3D project where the faulty component was inserted?
Create a new project and test it in it
Hartmut Eger
Senior Engineer
XING | LinkedIn
