I’m looking to see if Plant 3D has the ability to have an item bubble on the JOB MASTER BOM and then have that number used across all Ortho drawings for an entire project.
I did search the AutoDesk Community page and found this link below…this will work, but is not a great solution…I will have to still manually enter items and was hoping there was a better solution.
Example: Pipe 8” ND, A312 Gr 304L S/S to have item Bubble “5” in the Master BOM. On spool drawing 3, I want the ID number for this 8” Pipe to be Bubble/ID “5” not item “1” because it is the first item called out on the spool.
Have you found way to do this? I'm interested too in this feature. Please share your solution if such exists. By the way, I'm afraid that this task is impossible. Probably it will work only on single drawing with multiple viewports, layouts as it is stated in post 2 of similar topic which you have mentioned before. (It was 4 years ago, perhaps something was improved.)
As of now, the only solution I could come up with is to create a view of the entire skid, and then spool out each drawing as mentioned in other posts...I will let you know if I find a different / better way to do this...
