AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
ISO Annotation Symbols
15 REPLIES 15
Message 1 of 16
david.forsyth8QZCL
1058 Views, 15 Replies
Hi, when I run my new Iso template on a production ISO. I get these large bubbles for the bolts, gasket and flange.
I want to display 3 bubbles or 3 squares, I cant find out how to change this.
Also is it possiable to mate the the item 1 and 2 bubbles on the pipe and elbow in the screenhot below abit bigger so that when you print the iso it's easier to read?
Cheers
Dave
15 REPLIES 15
Message 2 of 16
h_eger
in reply to: david.forsyth8QZCL
Dear @david.forsyth8QZCL ,
please check in your IsoConfig.xml whether the two areas are identical.
<GroupScheme Name="FlangeGroup" AnnotationStyle="SRectangle" Enabled="true" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Components="Flange Bolt Gasket" Field="PartNumber" IncludeMate="true" MateComponent="Flange" MateTag="XX" MateAnnoStyle="Rectangle" MultipleBlocks="false">
            <Formats>
              <Format Component="Flange" Format="F{0}" />
              <Format Component="Bolt" Format="B{0}" />
              <Format Component="Gasket" Format="G{0}" />
            </Formats>
            <GroupFormats>
              <GroupFormat Count="1" Format="{0}" />
              <GroupFormat Count="2" Format="{0} {1}" />
              <GroupFormat Count="3" Format="{0} {1} {2}" />
              <GroupFormat Count="4" Format="{0} {1} {2} {3}" />
            </GroupFormats>
          </GroupScheme>
          <GroupScheme Name="FlangeGroupMulti" Enabled="false" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Components="Flange Bolt Gasket" Field="PartNumber" IncludeMate="true" MateComponent="Flange" MateTag="X00" MateAnnoStyle="OneCircle" MultipleBlocks="true">
            <Formats>
            </Formats>
            <GroupFormats>
              <GroupFormat Count="1" Format="{0}" AnnotationStyle="OneCircle" Tags="X00" />
              <GroupFormat Count="2" Format="{0}" AnnotationStyle="TwoCircle" Tags="X00 X03" />
              <GroupFormat Count="3" Format="{0}" AnnotationStyle="ThreeCircle" Tags="X00 X03 X06" />
              <GroupFormat Count="4" Format="{0}" AnnotationStyle="FourCircle" Tags="X00 X03 X06 X09" />
            </GroupFormats>
          </GroupScheme>
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 3 of 16
david.forsyth8QZCL
in reply to: h_eger
Hi @h_eger
Thankyou for the reply, This is what I have
the only thing that is different is the circle and rectangle. I would like to use the muiltiple bubbles format. im using version 2022 if that mates any difference
Cheers
Dave
Message 4 of 16
h_eger
I use the following setting for this result
<GroupScheme Name="FlangeGroupMulti" AnnotationStyle="Circle" Enabled="true" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Components="Flange Bolt Gasket" Field="PartNumber" IncludeMate="true" MateComponent="Flange" MateTag="X00" MateAnnoStyle="OneCircle" MultipleBlocks="true">
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 5 of 16
david.forsyth8QZCL
in reply to: h_eger
Awesome thankyou very much
Message 6 of 16
I put this exact code in and when I run the iso, no annotation shows up.  I have P3D 2023.
Message 7 of 16
h_eger
@dthompson45FWV ,
then you have made a mistake somewhere.
But we have no further information from your IsoConfig.xml to be able to help if necessary!
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 8 of 16
dthompson45FWV
in reply to: h_eger
Here's my complete isoconfig.xml.
Note that as a work around I was working on getting the flanges and gaskets to be not grouped at all.  So, when you look at the groups, you'll see "flange" and "gasket" as separate groups.  Just ignore it.
Message 9 of 16
h_eger
@dthompson45FWV ,
OK this is information that should come at the beginning of a conversation!
You should not use the flanges and gaskets as GroupSchema but as ComponentScheme.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 10 of 16
dthompson45FWV
in reply to: h_eger
I would still prefer to group them but that isn't working
Message 11 of 16
h_eger
@dthompson45FWV ,
a group requires at least 2 objects (Flange + BoltSet) or (Flange + Gasket) otherwise a group will not work.
Can you use an example to show how your desired result should look in the iso.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 12 of 16
dthompson45FWV
in reply to: h_eger
My desired output is exactly like the picture at the top of this thread.  If I use FlangeGroup - Flange + Gasket, it makes a small circle with 2 texts just like the picture earlier in this thread.  If I use FlangeGroupMulti, no annotations show up.
Making them single instances of circle annotations has nothing to do with my question and was only an attempt as a work around and should be ignored.
Message 13 of 16
h_eger
@dthompson45FWV ,
This appears to be a mistake.
The behaviour is identical to yours.
As soon as I try to display only Flange and Gasket on the iso I get no annatations.
P3D 2025
Please report to Autodesk Support.
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 14 of 16
dthompson45FWV
in reply to: h_eger
Thanks for looking at this.  Can we try putting the gasket and flange as separate annotations?
Message 15 of 16
h_eger
No, it does not work. Either all 3 (F B G) annos or none
Hartmut Eger
Senior Engineer
XING | LinkedIn
Message 16 of 16
dthompson45FWV
in reply to: h_eger
Okay, at least we know now
