I am currently testing Plant 3D 2025. When I open Plant 3D the first time and it automatically attempts to connect to the most recent project, I get the error message pictured below. After the error, if I browse and open the same Project.xml then the project loads fine. We do not have this issue in 2024.
"Failed to load Project file ...
FailedToLoadCache PnPCompletionStatus.FailedToOpenDatabse Connection Timeout Expired."
What is the project structure?
Local or server storage location of the project?
SQLite or SQL Server database
Local or ACC
with or without Vault
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Project is stored on a shared server (mapped as a network drive on my Windows machine) with SQL Server database. No ACC or Vault.
Do you also have the rights to access the SQL Server database in P3D 2025?
Hartmut Eger
Senior Engineer
XING | LinkedIn
Yes. I only get that error one time upon first opening Plant 3D. After I get the error, I click "OK", then I navigate to the very same Project.xml file on the shared server and it opens normally.
Then everything is fine again 😁
Hartmut Eger
Senior Engineer
XING | LinkedIn
Agreed - it’s not a big problem, just more of an annoyance since it happens every time I open Plant 3D 2025. I was wondering if others on 2025 see the same thing. I am also worried it will happen for everyone in my office, once we upgrade to 2025 - but I’m not sure yet since I’m the only one testing on 2025 so far.
I would wait a little longer before switching to P3D 2025. You will save yourself a lot of problems.
Hartmut Eger
Senior Engineer
XING | LinkedIn
